Здравейте.
Продавам CD Player Technics модел SL-PS7 с оригинални дистанционно и книжка в перфектно състояние , без драскотина -като нов.Само един собственик. Цена - 125 лв.
Снимки:
http://www.snimka.bg/profile.php?edit_p ... id=2460417
http://www.snimka.bg/profile.php?edit_p ... id=2460459
http://www.avland.co.uk/technics/slps7/
Техн. данни:
MASH* 1-bit DAC (24 bit High fs Processing) for High Quality Sound
Digital Re-Master Processing
TA-KEH II Capacitor and THCB for High Quality Sound
Newly developed TUI-Core transformer with low leakage flux
Virtual battery operation reduces noise from the power supply circuit
High slew rate, low distortion and low noise operation amp
Anti-vibration Technics hybrid die-cast panel
Optical digital output and gold plated analogue output terminals
Convenient CD editing function: edit guide, time fade, peak level search
Illuminated play (green) and pause (amber) keys
Centre disc tray design and centrally located optical mechanism for weight distribution
Auto cue pauses playback at the very beginning of the first sound on any selected track.
Remote control with 10-key direct access
10-key direct access on main unit
20-selection random access programming
Multi-function FL display with music matrix
Headphone jack with volume control
Specifications for the Technics SLPS7
Frequency Range 2Hz~20kHz (+/- 0.3dB)
Dynamic range 100dB
Signal to Noise ratio 115dB
Total Harmonic Distortion (1kHz,0dB) 0.0023%
Power Supply AC 230V, 50 Hz
Dimensions Width 430mm
Height 114mm
Depth 290mm
Weight 4kg
Продавам и триглав дек Technics модел: RS-AZ6 в перфектно състояние , без драскотина -като нов, оригинална книжка.Само един собственик. Цена - 125 лв.
Снимки:
http://www.snimka.bg/profile.php?edit_p ... id=2460468
http://www.avland.co.uk/technics/rsaz6/
Техн. данни:
Amorphous-Z Head significantly improves playback performance
ATC (Auto Tape Calibration) for optimum performance from each tape
Advanced tape transport mechanism - Hi-Speed FF/REW and Power Loading
Linear Magnetic-Field Class AA record EQ/amp
Anti-vibration THCB (Technics Hybrid Construction Base)
Dolby HX Pro & Dolby B/C NR systems
Hi-speed TPS (Tape Program Search)
Linear electronics counter with memory stop
Auto tape/source monitor select
MPX filter on/off
Infra-red remote control capability with selected Technics amplifiers and receivers
Specifications for the Technics RSAZ6
Wow and flutter 0.07% (WRMS)
Frequency response (DIN) Normal Tape 20Hz-18kHz
High Position Tape 20Hz-19kHz
Metal type 20Hz-24kHz
S/N ratio Dolby C NR on 78dB (A-weighted)
Dolby B NR on 71dB (A-weighted)
Capstan drive DC servo (x1)
Reel drive DC (x1)
Height 125mm
Depth 290mm
Weight 3.9kg
Поздрави.
Росен.
тел.0887255757
balkan_gb@abv.bg
ICQ: 114287528
ПРОДАДЕНИ Technics CD Player SL-PS7 и триглав дек RS-AZ6
Последно промяна от Roojo на Пон Мар 26, 2007 10:13 am, променено общо 1 път.
