Променливи Кондензатори от сн. 1
Поз.........Разм. (l1 - l)..............Тип...............Стойности.........Бр.......................Цена:
1....................17мм.........................................................12....................1.00лв./бр.
2.............ф12х16мм.........................................................12....................1.50лв./бр.
3.............ф16х17мм..........................................................8....................2.00лв./бр.
4...............11-20мм...........1КПВМ-3.........1,8-9pF/350V............38....................1.00лв./бр.
................13.6-22.5мм.......1КПВМ-2.........2,5-15pF/350V............11...................1.50лв./бр.
5...............17-26мм............1КПВМ-1..........3-24pF/350V..........298....................1.50лв./бр.
6...............16-26мм.................................2-20pF/350V..........18...................2.50лв./бр.
7...............14-29мм.................................4-24pF/350V..........12...................2.50лв./бр.
8...............21-29мм...........................................................8...................3.00лв./бр.
За справка относно размерите l и l1 в този линк:
http://www.eandc.ru/pdf/kondensator/kpvm.pdf
Променливи Кондензатори от сн. 2
1.................12-15мм.........................................................3....................1.00лв./бр.
1...................9-12мм.........................................................3....................1.00лв./бр.
2.................12-15мм.........................................................4....................2.00лв./бр.
3.................17-28мм....................................4-16pF.............1....................2.50лв./бр.
3.................15-25мм.........................................................4....................2.00лв./бр.
4.................14-23мм.........................................................4....................2.00лв./бр.
5.................17-26мм....................................2-20pF............43....................2.50лв./бр.
6.................28-36мм...................................30-150pF..........18....................3.00лв./бр.
7.................13-23мм(свал.).................................................3....................2.00лв./бр.
8.................16-27мм.........................................................18...................3.00лв./бр.
9.................28-43мм...................................4-24pF.............12....................4.00лв./бр.
10...............27-37мм...................................3-43pF..............12....................4.00лв./бр.
11.................20-37мм...................................1-5pF................2....................3.00лв./бр.
12.................19-33мм..........................................................6....................3.00лв./бр.
13.................17-35мм..........................................................2....................3.00лв./бр.
14.................33-73мм.........................................................11....................6.00лв./бр.
Променливи Кондензатори от сн. RAZNI
Поз.....Разм. (за ориентир).........Тип.........Стойности................Бр.......................Цена:
1...................30х45мм.........................................................1....................2.00лв./бр.
2...................10х16мм(свал.)................................................1....................1.00лв./бр.
3...................20мм(свал.).....................................................1....................1.00лв./бр.
4...................13х26мм..........................................................1....................2.00лв./бр. Продаден
5...................18х21мм..........................................................1....................2.00лв./бр.
6...................11х22мм(свал.)..................................................1....................1.00лв./бр.
7...................14мм...............................................................2....................1.00лв./бр. Продадени
7...................10мм...............................................................8....................1.00лв./бр. Продадени
8...................12мм..............................................................17....................1.00лв./бр.
9...................13-25мм...........................................................2....................2.00лв./бр. Продадени
10...................17мм.................................1.8-13pF..................1....................2.00лв./бр.
11...................9-14мм(свал.)..................................................1....................1.00лв./бр.
12...................10-14мм.........................................................1....................1.00лв./бр.
13......................................................................................5.....................0.60лв./бр.
Променливи Кондензатори от сн. Единични_Бройки
1...................43х56мм.........................................................1....................5.00лв./бр.
2...................33х58мм.........................................................1....................4.00лв./бр.
3...................44х52мм.........................................................1....................4.00лв./бр.
3...................34х44мм.........................................................1....................4.00лв./бр.
4...................26х48мм.........................................................1....................4.00лв./бр.
5...................28х46мм.............................4 - 20pF...................6....................3.00лв./бр.
6...................28х50мм.........................................................1....................4.00лв./бр.
7...................33х43мм.............................2 - 2,5pF..................1....................3.00лв./бр.
8...................33х43мм.............................4 - 28pF...................1....................4.00лв./бр.
БОБИНИ навити в/у керамично тяло със стъпка на керам. тяло - сн. Bobini по-горе
Поз.......Разм. на кер. т.............Ф на пров............бр. на нав..............Бр.............Цена:
1................ф13х36мм.................ф0.8мм............6, 10, 13, 14, 16........48..............2.00лв./бр.
2................ф20х39мм.................ф2.0мм.............................5, 9......10..............3.00лв./бр.
3................ф18х64мм.................ф0.2мм..........три усукани пров.........1..............3.00лв./бр. Продадена
4................ф17х37мм....................................................................1..............2.00лв./бр. Продадена
4................ф20х30мм....................................................................2..............2.00лв./бр. Продадени
5................ф21х29мм.................ф1мм(прибл.)............9.....................1..............3.00лв./бр. Продадена
6................ф17х37мм....................................................................1..............3.00лв./бр. Продадена
7................ф8х37мм......................................................................1..............2.00лв./бр.
8................ф12х22мм....................................................................1..............1.00лв./бр.
9................ф6х17мм......................................................................1..............0.50лв./бр. Продадена
9................ф9х21мм......................................................................1..............1.00лв./бр. Продадена
За контакти:
vtraikov@gmail.com
Продавам Променливи (възд.) конденз. тип КПВМ и др. и БОБИНИ
Temenuzhka_Venko56
- Местоположение: Благоевград
Последно издигане Temenuzhka_Venko56 от Съб Юли 01, 2017 4:14 pm
+359885553535
