PHILIPS
10.000mF/16V......................................22бр......................9.00лв./бр. (сн. Capacitors)
220mF/100V..........................................4бр......................1.50лв./бр. (сн. Philips_Frolyt_Sprague)
2200mF/100V.........................................8бр......................6.00лв./бр. http://www.ebay.com/itm/PHILIPS-BC-058- ... SwtnpXjfwX
150mF/250V...........................................5бр......................7.00лв./бр.
1500mF/250V..........................................1бр......................9.00лв./бр.
220uF 385V 85°C Ф30x40 mm...................6бр......................3.00лв./бр.
ROE 82 000mF/25V..............................20бр.......................24лв./бр. http://www.comaat.com/product/63/roe-82-000-uf-25v.html
EPCOS (S+M)
680mF/450V..............................11бр.......................12лв./бр.
820mF/450V..............................26бр.......................14лв./бр.
1000mF/450V............................15бр.......................15лв./бр.
1500mF/420V..............................1бр.......................15лв./бр.
NEGATIV BLANK (NIPPON CHEMI.COM)
15000mF/100V, +85 C (ф50х75мм)......4бр.......................9лв./бр. продадени
820mF/200V, +105 C (ф35х40мм)........2бр.......................7лв./бр.
10000mF/35V, (ф26х40мм).............4бр.......................4лв./бр.
NICHICON CE radial electrolytic capacitor
1500uF 250V 85°C 35x51 mm ............4бр......................6лв./бр.
ELNA - NEG (Made in JAPAN)
4700mF/80V, 85 C (ф26х51мм).........18бр.......................7лв./бр.
CE(M) (Made in JAPAN)
330mF/63V,-40+ 85 C (ф13х20мм)........2бр.......................1лв./бр. (демонтирани)
330mF/250V, +105 C (ф30х26мм).........5бр.......................5лв./бр.
6800mF/50V, +85 C (ф22х50мм)..........2бр.......................7лв./бр.
6800mF/63V, +85 C (ф25х50мм)..........4бр.......................7лв./бр.
Rubycon CE NEG
100mF/100V, +85 C (ф20х35мм)..........6бр.......................5лв./бр.
1000mF/100V, +85 C (ф20х35мм)........3бр.......................1лв./бр. (демонтирани -сн. Rubycon_Siemens)
Frolyt 100uF 25V Best Military Axial Tantalum (ф9х19мм) .......5бр......5.00лв./бр. https://www.ebay.com/i/182617841559?rt=nc
FROLYT 220mF/40V (ф10х26мм) ................8бр...........0.80лв./бр.
FROLYT 470mF/40V (ф12х32мм) ................10бр...........1.00лв./бр. https://www.ebay.ca/itm/470-uF-40-V-LOT ... SwTM5YuY00
FROLYT 470mF/63V (ф14х37мм) ................8бр...........1.00лв./бр. https://www.ebay.com/itm/4-x-NOS-Frolyt ... 1607687566
FROLYT Elyt TGL 1000mF/40V (ф16х40мм) ....4бр...........1.50лв./бр. (сн. Philips_Frolyt_Sprague)
FROLYT Elyt TGL 1000mF/25V (ф14х41мм)......6бр...........1.00лв./бр. (демонтирани) http://shopotam.ru/catalog/Consumer_Ele ... -item.html
FROLYT 0.47mF/80V (ф5х12мм - Radial) ........7бр...........0.50лв./бр.
SIEMENS SIKOREL 22mF/63V (ф9х13мм) .........5бр...........0.50лв./бр. (демонтирани -сн. Rubycon_Siemens)
SPRAGUE 1000mF/100V (ф30х32мм) ....1бр...........2.50лв./бр. (сн. Philips_Frolyt_Sprague)
За контакти:
vtraikov@gmail.com
Продавам маркови електролитни кондензатори
Temenuzhka_Venko56
- Местоположение: Благоевград
Последно издигане Temenuzhka_Venko56 от Чет Юли 28, 2016 7:48 pm
+359885553535
