Затворен обем за Dynaudio MW 190?? Препоръки...?
Модератори: guitman, DLS
Staykov,anton
#1 Мнение от Staykov,anton »
Предложения?!- няма.....
Technical Specifications
Thiele Small Parameters:
Sens 92 dB
Nominal Impedance (Znom): 4 Ohm
DC Resistance (Re): 3.8 Ohm
Voice Coil Inductance (Le): 0.29 mH
Resonance Frequency (fs): 31Hz
Mechanical Q Factor (Qms): 2.97
Electrical Q Factor (Qes): 0.64
Total Q Factor (Qts): 0.53
Mechanical Resistance (Rms): 2.70 kg/s
Moving Mass (incld. air load, Mms): 40.6 g
Suspension Compliance (Cms): 0.63 mm/N
Effective Dome Diameter (d): 225.6 mm
Effective Piston Area (Sd): 400 cm squared
Equivalent Volume (Vas): 143.4
Force Factor (Bl): 6.8 Tm
Recommended Frequency Range: 20-800 Hz
Recommended closed box volume 56.5-113 l
Magnet and Voice Coil
Voice coil diameter (dc): 100 mm
Voice coil height (hc) : 17 mm
Voice coil layers (nc): 2
Magnetic gap height (hg): 8 mm
Linear excursion: 9 mm
Max. excursion: 28 mm
Magnet weight (wm): 0.94 kg
Power Handling
Nominal long term IEC: 190W (crossover dependent)
Transient (10ms): 1000W
Mechanical Properties
Net Weight: 2.3 kg
Overall dimension: 300.5 mm diameter x 102 mm
