7.1 ресивър за домашно кино. Сребрист на цвят. Техническо и външно състояние - като нов. Продава се в оригинален кашон с инструкция за употреба, оригинални дистанционно, калибровъчен микрофон, антена. Цена - 800 лв.
Информация за продукта:
The Latest Audio and Video Support
• Deep Color 30/36 bits colour depth and xvYCC broader colour space support.
• HDMI1.3a inputs/outputs allow to handle video signal with
higher speed.
State-of-the-art Denon Solutions for Maximising Content Quality
• Identical quality and power for all 7 channels, 100W x 7ch
• New 32bit floating point DSP
• Compressed Audio Restorer
Denon's new audio technology for MP3/WMA/AAC compressed format to reproduce higher frequency range and deeper bass sound. This new audio technology provides better sound for iPod.
• Latest version Mult EQ
-New tower type microphone for more accurate measuring
-Maximum six points measurements
-New filtering ALFC(Adaptive Low Frequency Correction) for higher resolution processing in low frequency band.
• HD Video Circuit
-Discrete and latest devices for ultimate HD video performance in each block.
• New Chassis Construction for clear audio and video signal
-Minimum signal path
-Direct Mechanical Ground for stable drive
-Separate unit design
• Digital / Analog separate winding
• Large-output power amp section and power supply configuration, for stable high-power output
• Stable power supply for high-quality sound and picture playback
• 24 bit/192 kHz D/A converter for all channels
• Pure Direct mode, for the enjoyment of music in high-quality sound
• Supports the most advanced surround playback formats
Dolby Digital EX / Dolby Digital / Dolby Pro Logic IIx
DTS-ES / DTS 96/24 / DTS Neo:6 / DTS
• Variable subwoofer crossover switching
• Pre-amp with Variable Gain Volume
Connectivity & Future-ready Expandability
• HDMI™ inputs with 1080p capability
• Video Up conversion capable of output to HDMI
Specifications
Input / Output terminals
IN HDMI 2
Component 3
S-Video 3
Composite 4
Analog audio 8
Digital OPT 2
Digital COAX 2
iPod ready 1
Out HDMI 1
Component 1
S-Video 2
Composite 2
Analog audio 2
Digital OPT 1
Pre out 8 ch
Digital Media Connectivity
• iPod® audio, photo and video playback (optional ASD product family)
Ease-of-Use
• Auto set-up and Room EQ, featuring MultEQ from Audyssey
• New back panel layout
Ease-of-Use
• 3 Quick Select Buttons
• Auto Surround Back Channels ON function, for auto-detection of supporting sources
• Auto Surround mode
• Audio Delay function (max. 200 msec)
• Night Mode for neighbour friendly listening
• Muting level settings (∞/-40dB/-20dB)
• Audio Level Memory, capable of correcting different signal levels for each input device
• Volume Level Limiter, for setting maximum volume levels
• Power-ON Volume Level Memory
• Preset remote control unit
Power Amplifier Section
Rated output *THD figures are power amp stage values. Front 90 W + 90 W (8 ohms, 20Hz - 20kHz)
Centre 90 W (8 ohms, 20Hz - 20kHz)
Surround 90 W + 90 W (8 ohms, 20Hz - 20kHz)
Surround back 90 W + 90 W (8 ohms, 20Hz - 20kHz)
Preamplifier Section
Input sensitivity/impedance Audio inputs 200 mV/47 kohms
Output level/Load impedance Rec. Audio outputs 200 mV/47 kohms
FM
Tuning frequency range 87.5 - 108.0 MHz
Usable sensitivity 1.0 μV (11.2 dBf)
AM Section
Tuning frequency range 522 - 1611 kHz
Usable sensitivity 18 μV
General
Power supply AC 230 V, 50 Hz
Dimensions (WxHxD) 434 x 171 x 383 mm
Weight 11.2 kg
Тел за връзка - 0886 610 719
Скайп - sarrummann
Мейл - jls@abv.bg
DENON AVR 1908
- akustichen
- Регистриран на: Сря Ное 14, 2007 1:00 am
DENON AVR 1908
Последно издигане akustichen от Чет Авг 12, 2010 4:55 pm
Потребители разглеждащи този форум: 0 регистрирани и 59 госта
