ONKYO CP-1046F Quartz Locked Direct Drive Fully Automatic Turntable
Много добър външен вид и отлично техническо състояние.
Пълен автоматик, директ драйв мотор, кварцово стабилизиран.
Нова доза Audio-Technica. Много прецизно работеща автоматика.
Цена - 170 лв.
The Onkyo CP-1046F is a 2-speed, direct-drive turntable system featuring auto lead-in and return, reject, repeat, cue and search functions.
Specifications
Type: 2-speed fully automatic turntable
Platter: 310mm aluminium alloy
Motor: quartz locked direct drive brushless DC motor
Speeds: 33 and 45rpm
Wow and flutter: 0.025% WRMS
Rumble: better than 75dB
Tonearm: Static balance straight-type pipe arm
Effective length: 224mm
Overhang: 13mm
Offset angle: 21 degrees
Cartridge: OC-61 VMS moving magnet (Ortofon FF15E mkII)
Frequency response: 20Hz to 20kHz
Tracking force: 2g
Output: 3.5mV
Replacement stylus: DN-61ST
Dimensions: 418 x 132 x 376mm
Weight: 6.0kg
Optional headshell: SH-21E
Росен Христов
тел.0887255757
balkan_gb@abv.bg
Продавам грамофон ONKYO CP-1046F Quartz Locked - Продаден!
