ïèòàíå çà ðåñèâúð + êîëîíè
AdsBot [Google]
ïúðâî çäðàâåéòå
êàêâî ìèñëèòå çà ìàðêàòà eltax è ïî-ñïåöèàëíî çà
LTAX AVR-200 + Mirage 5pack
çà ðåñèâúðà :
Max power 8 Ohm Music 5 x 60W
Max power 8 Ohm Music Sub 120W
Tuner presets 30
Surround formats Dolby Digital (AC-3), Dolby ProLogic
DSP effects Yes
Analoge audio inputs DVD, VCR, Tape, CD, AUX
Digital Optical audio inputs Yes
Digital coaxial audio inputs Yes
Antenna inputs FM, AM
Speaker outputs 5.1 speaker output
Subwoofer RCA line-out Yes
Mains voltage 220-240V / 50-60Hz
Dimensions (HxWxD) 152x430x335mm
Weight 7.3Kg
Manual languages English, German, French, Dutch, Spanish, Danish
Remote control Yes
Batteries 2 x AAA Included
Antennas FM & AM included
çà êîëîíèòå Recommended amplifier AV-Amps 30-120 watt RMS per channel
Front
System 3 way bass refl ex
Tweeter 25mm Soft dome
Midrange 130mm
Woofer 130mm
Long term max power 100 Watt
Short term max power 120 Watt
Sensitivity (2,83V/1m) 89dB
Frequency Range 50-20.000Hz
Impedance 8 Ohm
Terminal connection Binding post
Cabinet Finishes Light Beech
Dimensions (HxWxD) 820x185x272mm
Weight 9.3 Kg
Included accessories 3x3m Speaker cable
2x5m Speaker cable
Centre
System 2 way closed box
Tweeter 22mm Soft dome shielded
Midrange -
Woofer 2 x90 mm shielded
Long term max power 70 Watt
Short term max power 100 Watt
Sensitivity (2,83V/1m) 88dB
Frequency Range 80-20.000Hz
Impedance 8 Ohm
Terminal connection Clip
Dimensions (HxWxD) 125x260x165mm
Weight 2.4Kg
Included accessories Rubber feet
Rear
Midrange -
Woofer 90mm
Long term max power 60 Watt
Short term max power 90 Watt
Sensitivity (2,83V/1m) 87dB
Frequency Range 85-20.000Hz
Impedance 8 Ohm
Dimensions (HxWxD) 160x125x165mm
Weight 1.3 Kg
Included accessories Wall bracket
äà çíàì ÷å ðåñèâúðúò å ìàëêî ñëàáè÷úê çà òåçè êîëîíè íî êîìïëåêòà ãî ïðîäàâàò çà 600ëâ :lol: à èíà÷å êîëêîíè 600ëâ è ðåñèâúð 300ëâ :?: :roll:
oceanman
#3 Мнение от oceanman »
Лично аз не обичам да си купувам неща от този ценови клас...Но мнението ми за Елтакс е добро.Спвциално тези модели не съм ги слушал,но мисля ,че за парите си сделката е направо изумителна.не знам колко е добър Ресивъра,но мисля,че от малките "дръжкофончета ще е доста по-добър...Така,че за 600 лв колони и ресивър-не се замисляй...
Потребители разглеждащи този форум: Google [Bot] и 5 госта
