Продавам Harman Kardon HK 3380 Stereo Receiver
rewri
Регистриран на: Чет Окт 22, 2009 11:13 am
#1 Мнение от rewri »
Ползван 2 години.
Без следи от употреба.
Цена: 550 лв
Бижуто се намира се в Пловдив
Телефон за контакти: 0885 62 62 16
SPECIFICATIONS:
Audio
Stereo Mode :
Continuous Average Power (FTC) Per Channel : 80 Watts per channel, 20Hz – 20kHz @ <0.07% THD, both channels driven into 8 ohms
100 Watts per channel, 20Hz – 20kHz @ <0>80dB
IF Rejection : >100dB
Tuner Output Level : 1kHz, ±100kHz, Dev 500mV
AM Tuner
Frequency Range : 520 – 1710kHz
Signal-to-Noise Ratio : >40dB
Usable Sensitivity : Loop 500µV/M
Distortion : 1kHz, 50% Mod 0.8%
Selectivity : ±10kH, >25dB
Video
Television Format : NTSC/PAL/SECAM
Signal Format System : Composite
Input Level/Impedance : 1Vp-p/75 ohms, unbalanced
Sync Polarity : Negative
Output Level/Impedance : 1Vp-p/75 ohms, unbalanced
Video Frequency Response : 10Hz – 10MHz
General
Power Requirement : AC 220-240V / 50Hz
Power Consumption : 3W standby, 200W maximum (both channels driven)
Unit Dimensions :
Width : 442mm (17.4 inches)
Height : 168mm (6.6 inches)
Depth : 382mm (15 inches)
Unit Weight : 9.48kg (20.9 lb)
Потребители разглеждащи този форум: 0 регистрирани и 30 госта
