WOOFER W200S
WOOFER W200S
#1 Мнение от Kiril Kirilov »
Продавам нискочестотен драйвер Visaton W 200 S,
Technical Data:
Rated power 75 Watt
Maximum power 115 Watt
Nominal impedance 4 Ohm
Frequency response (-10 dB) fu - 6000 Hz
(fu: Lower cut-off frequency depending on cabinet) .
Mean sound pressure level 88 dB (1W/1m)
Maximum cone displacement 20 mm
Resonance frequency fs 30 Hz
Magnetic induction 1,1 Tesla
Magnetic flux 600 µ Weber
Height of front pole-plate 5 mm
Voice coil diameter 3,5 cm
Height of winding 1,2 cm
Cutout diameter 18,4 cm
Net weight 1,5 kg
D.C. resistance Rdc 3,7 Ohm
Mechanical Q factor Qms 3,47
Electrical Q factor Qes 0,33
Total Q factor Qts 0,3
Equivalent volume Vas 65 l
Effective piston area Sd 214 cm2
Dynamically moved mass Mms 28 g
Force factor Bxl 7,7 T · m
Inductance of the voice coil L 1,5 mH
Нов, недокосван, цена 60 лв.
