Продавам subwoofer B&W ASW1000 Made in England
Цена 580 лева - 0888 516 826 Стайков
* Frequency Response:±3dB 25Hz - 40/140Hz adjustable response
* Low-Pass filter:Active 4th-order, variable cutoff frequency 40-140Hz
* High-pass filter (Line level):active 3rd-order at 80 Hz
* High-pass filter (Speaker level):passive 1st-order at 80Hz into 8 ohm resistor (response using speaker level connections dependent on satellite impedance)
* Sensitivity:90dB spl (2.83V 1m)
* Power output:120W continuous
* Signal/Noise:90dB
* Input Impedance:22kohms
* Functions:Input Level Phase 0/180 -Low-pass filter frequency -1x 300mm (12in) dia long-throw with magnetic shielding
* Dimensions:Height: 460mm /Width: 540mm /Depth: 500mm
* New Weight: 30kg
* Cabinet:Black Ash Vinyl
* Grille:Black Cloth
