Качествен усилвател MARANTZ PM50-Продаден!
Anonymous
#1 Мнение от Anonymous »
Качествен усилвател MARANTZ PM50-2X120W-4OM,2X80W-8OM-0.008%,10KG=
Rating of a mode
Form Stereo Integrated Amplifier
Output power
(20Hz - 20kHz, both channel simultaneous drive) 120W+120W (4ohms)
100W+100W (6ohms)
80W+80W (8ohms)
Dynamic power 240W+240W (2ohms)
180W+180W (4ohms)
140W+140W (6ohms)
THD (20Hz - 10kHz, 8-ohm load intensity) 0.008%
Cross modulation distortion (SMPTE) 0.008%
Frequency characteristic compact disk and a Source Direct: 10Hz-100kHz+0 -3 dB
Dumping factor (8-ohm load intensity) 180 (20Hz - 10kHz)
Input sensitivity/impedance Phono MC: 250 microvolts/100 ohms
Phono man month: 2.5mV/47kohm
High SFT Level: 150mV/33kohm
Phono maximum permissible input (1kHz) MC:16mV
MM:160mV
RIAA deflection (20Hz - 20kHz) ±0.2dB
SN ratio (A network) Phono MC:75dB
Phono MM:85dB
High Level:105dB
Tone control Bass: 100Hz, ±6dB
Treble: 10kHz, ±6dB
Power source AC100V, 50/60Hz
Power consumption 180W (Electrical Appliance and Material Control Law)
Dimensions Width 420x height 150x depth of 380mm
Weight 10.0kg
230лв.
