Два ретро Marantz-а
vs-audio
Регистриран на: Нед Мар 23, 2008 1:00 am
Местоположение: София, ул. Поп Богомил 41
Два ретро Marantz-а
#1 Мнение от vs-audio »
30 годишен стерео ресивър Marantz 2226BL
Мощност 2x26 вата.
Цена 230лв
И още едно ресивърче от същата марка, модел 1515L, но за съжаление не можах да намеря инфорация за него.
Цена 210лв
За информация : info@vs-audio.com или Лично съобщение
Последно промяна от vs-audio на Нед Апр 06, 2008 11:14 pm, променено общо 1 път.
vs-audio
#2 Мнение от vs-audio »
Ето и малко по-подробна информация за ресивърите
General Marantz 2226BL
Description Receiver (Euro)
Rarity X-Rare
Designed in USA
Manufactured In Japan
Wood Case WC-122 walnut veneer cabinet
Silver Face Yes, extruded
Channels Two
Speaker Connections Two Pair
Chassis Ground Yes
AC Switch Yes
Switched AC Outlets None
Unswitched AC Outlets None
Physical
Panel Width 17 1/4
Panel Height 5 3/8
Amplifier
RMS Power Per Channel 26
FM Tuner
Gyro Tuning Yes
300 Ohm Binding Posts Yes
75 Ohm Binding Posts Yes
75 Ohm F Connector Yes
Signal Strength Meter Yes
Center Tuning Meter Yes
Illuminated Dial Pointer Yes
AM Tuner
Signal Strength Metering Yes
External Ferrite Antenna Yes
Shortwave Frequency Tuning Range LW
Ferrite Antenna Yes
Preamplifier
Single Bass Adjustment Yes
Single Midrange Adjustment Yes
Single Treble Adjustment Yes
High Filter Yes
Low Filter Yes
Loudness Contour Yes
Mono Yes
Muting Yes
Balance Yes
Number of Tape Monitors One
Auxillary Input Source Yes
Phono Input Source Yes
Cartridge Load 47k ohm
Headphone Jack(s) Yes
General Marantz 1515L
Retail Price 230
First Year 1978
Last Year 1980
Wood Case WCV-115
Silver Face Yes
Channels Two
Speaker Connections Two Sets
AC Switch Yes
Unswitched AC Outlets One
Physical
Width 17 1/4
Height 5 3/8
Depth 14 1/8
Weight 22 lbs, 12 oz
Amplifier
RMS Power Per Channel 15 @ 8 ohms, 17 @ 4 ohms
Total Harmonic Distortion (THD) 0.08%
Power Bandwidth 20 Hz to 20 KHz
FM Tuner
Mono Switch Yes
Stereo Lamp Yes
Muting Switch Yes
AM Tuner
Antenna binding Posts Yes
Preamplifier
High Filter Yes
Gain Control knob
Balance knob
Tuner Source Input AM/FM
Source Tape Input (as opposed to a tape monitor) Yes
Tape Monitor Yes
Speaker Selection Nomenclature 1, 2
Информацията е взета от http://classic-audio.com
antondinkov
къде
#3 Мнение от antondinkov »
къде може да се чуе и види?
