Продавам кондензатори и ПРЕЦИЗНИ резистори
- emil_petrov
- Регистриран на: Чет Юли 13, 2006 12:00 am
с този цвят са означени останалите наличности към дата 23.10.2008
К71-7 ( Полистирольные Polystyrol film )
1. 4.7nF 2% 250V.........60.........0,66лв
3. 200nF 1% 250V..........29.........0,85лв
МПО също е полистирол
4. МПО - 0.03мкФ - 400В 5% ....... 100........ 0.30
К78-2 ( Полипропиленовые Polypropylene )
1. 4.7nF 1.6kV.........65.........0,30лв
КБГ-И "Конденсатор бумажный герметизированный-изолирован". Диэлектрик- бумага в церезине, обладки- алюминиевое напыление. Корпус - порцелан.
1. 6800pF 5% 600V........160...... 0,50лв......L=26mm D=8mm gray
2. 6800pF 10% 600V........150.....0,50лв......L=26mm D=8mm gray
КСО -"Конденсатор слюдяной опресованный" silver-mica
KCO-2г-250-680.........680pF/250V 5%........ 250.......0,20.....14x7mm
KCO-2б-500-1000......... 1nF/500V 5%........ 100.......0,30.....18x11mm
KCO-2в-500-1000........ 1nF/500V 5% .........464.......0,30.....18x11mm
KCO-2г-500-1000........ 1nF/500V 5% ......... 1300......0,30.....18x11mm
KCO-2г-500-1800........ 1.8nF/500V 5% .......186........0,30.....18x11mm
KCO-2б-500-1800........ 1.8nF/500V 10%..... 260........0,30......18x11mm
KCO-2г-500-2200........ 2.2nF/500V 5%....... 2040.......0,30......18x11mm
KCO-5а-500-3000........ 3nF/500V 5%......... 560........0,30......20x20mm
KCO-5-500A-3300........ 3.3nF/500V 10%.....470........0,30.......20x20mm
KCO-5г-250-10000........ 10nF/250V 5%......280.........0,50.......20x20mm
имам и български КСО , но с плоски изводи и доста повече сребро .
Следните стойности са по 0.30 лв и има поне по 100бр
56pF/10%/500V
68pF/10%/500V
100pF/10%/500V
140pF/5%/500V
200pF/10%/500V
430pF/10%/500V
680pF/10%/500V
1000pF/10%/500V
k53-4 Ниобиевый оксидно-полупроводниковый конденсатор
К 53 - 4 6 V 10 µF.................125.........0,20
К 53 - 4 6 V 15µF..................190.........0,20
К 53 - 4 6 V 22µF...................110.........0,20
К 53 - 4- 6 V 33 µF.................200.........0,20
К 53 - 4- 6 V 47 µF.................188.........0,20
К 53 - 4- 6 V 68 µF.................70.........0,20
(Конденсатор бумажный)
МБМ - 0.0051мкФ - 1500В .......590......... 0.30
МБМ - 0.05мкФ - 1000В............240......... 0.30
МБМ - 0.5мкФ - 160В ............... 90 ...... 0.30
БМТ-2 - 0.047мкФ- 400В ...........110 ...... 0.20
Метализирана хартия ( МБГх )
продадени
ще добавя още видове по късно .....
56pF/10%/500V
68pF/10%/500V
100pF/10%/500V
140pF/5%/500V
200pF/10%/500V
430pF/10%/500V
680pF/10%/500V
1000pF/10%/500V
продадени
Последно промяна от emil_petrov на Чет Окт 23, 2008 11:09 pm, променено общо 19 пъти.
e-mail: promics@engineer.bg ( предпочитан контакт )
Skype: emil_petrov
ICQ: emil_petrov
Phone: 02/8845977
GSM: 0885590692
София
Skype: emil_petrov
ICQ: emil_petrov
Phone: 02/8845977
GSM: 0885590692
София
- emil_petrov
още кондензатори
Polystyrene Axial Lead ( стирофлексни )
ПРОДАДЕНИ са ВСИЧКИ СТИРОФЛЕКСНИ
Метализиран филм
KS/A..........Koweg.........10nF / 1% / 25V.( Polystyrol )....213...........0,30 ......[ кубче 12 x 12 x 12 ]
на следващите два вида не знам какъв е диелектрика
Banjasa........1uF 250V.... ? Film...... 180........0,30 axial........[L= 26 x D =15 ]
NCP-642....REMIX......22nF 20% 63V.....? film....209..........0.30 axial........[ L= 20 x D = 5 ]
Метализиран филм
Последно промяна от emil_petrov на Чет Окт 23, 2008 11:05 pm, променено общо 4 пъти.
Skype: emil_petrov
ICQ: emil_petrov
Phone: 02/8845977
GSM: 0885590692
София
Skype: emil_petrov
ICQ: emil_petrov
Phone: 02/8845977
GSM: 0885590692
София
- emil_petrov
ПРЕЦИЗНИ РЕЗИСТОРИ
Сивите са С2-13 ---- Metal film precise ( Металодиелектрически, прецизни, нискошумящи ( около 1 мкВ/В )
С2-13-0.5% - 0.25W : ( по 0.1лв )
301 Ω - 580 бр
3,01 kΩ - 820 бр
30,1 kΩ - 460 бр
301 kΩ - 840 бр
499 Ω - 503 бр
4,99 kΩ - 720 бр
49,9 kΩ - 420 бр
499 kΩ - 941 бр
( по 60 бр са в кутия - 15 бр на картонче)
С2-13-0,1% - 0.25W Б-В
...... 361 Ω - 155 бр х 0.20лв
High Precision Metal film resistor производство на ИМЕ ( сините и червените )
тях съм ползвал при проектиране на 12-16 битови АЦП и ЦАП, но първите отзиви за аудио приложения са отлични...
Това което знам за резисторите е:
Относителна точност dR/R = 0.1 … 1% ; ТКС = мах 25ppm ( типично 5-10ppm) ; Umax ( за 5 минути ) = 1000V
Съпротивителният елемент е от нихром NiCr нанесен във вакуум върху керамична подложка от 'ситал' СТ-50-1.
Подложени са на термична тренировка при 380-400 градуса С за 10 минути.
Върху съпротивителния слой е отложен златен или сребърен слой.
Caddock произвежа подобни ( http://www.partsconnexion.com/catalog/r ... et003.html )
това са стойностите с които разполагам --- като цените са производствените на ИМЕ от 1988 -1990г.
Новите цени ( от 02.05.2008 ) са 1лв/бр за буква В ( 0.1%) и 0.50лв за всички останали
червени
142RB- 0.125W.....1985 .....3.63лв
261RF- 0.25W.........731 ......1.70
845RF- 0.125W.......706......1.13
1K5F- 0.125W.........138......1.13
2K04F - 0.125W......73........1.13
2K7F- 0.125W.........105......1.13
3K16F- 0.125W.......78........1.13
3K75B- 0.125W.......102......3.63
3K75F - 0.125W.......93.....1.13
4K99D- 0.125W........186.....1.71
6KB- 0.125W............0.....3.63
6K81FD- 0.125W........67......1.13
7K96D- 0.125W..........95......1.71
11K5D- 0.125W.........115.....1.71
24K9F- 0.125W...........97.....1.13
45K3D- 0.125W.........108.....1.71
110KD- 0.125W.........110.....1.71
252KD- 0.125W.........160.....1.71
сини
100RF - 0.125W........158.....1.13
100RB - 0.125W........95......5.72
261RF - 0.125W........312......2.05
845RF - 0.125W.........310......2.05
1KB- 0.25W................160.....5.46
1K 0,1% - 0.25W........261.....5.46
10KF - 0.125W...........50.......1.13
110KB - 0.125W.........114.....5.72
252KB - 0.125W.........118.....5.72
разполагам и с въглероднослойни ВС, УЛМ и С2-10 ---- до 2 вата . Нямам точен опис- на място е най- добре- цените са 10ст за до 0.5 Вата, а за 1 и 2 вата - 20 ст
Поздрави и успех
Последно промяна от emil_petrov на Сря Окт 22, 2008 9:50 pm, променено общо 11 пъти.
Skype: emil_petrov
ICQ: emil_petrov
Phone: 02/8845977
GSM: 0885590692
София
Skype: emil_petrov
ICQ: emil_petrov
Phone: 02/8845977
GSM: 0885590692
София
- Svetoslav Kocev
- Регистриран на: Пон Сеп 26, 2005 12:00 am
- emil_petrov
Уточнение
Толеранса на резисторите на ИМЕ е обозначен по следния начин:
В --- 0.1%
С --- 0.25%
D---- 0.5%
F ---- 1%
Цените се променят както следва ( тъй като очевидно са били и са твърде скъпи ) :
за буква В - 0.1% ---- 1лв /бр
за всички останали букви : --- 0.50лв/за брой
Поздрави и успех
В --- 0.1%
С --- 0.25%
D---- 0.5%
F ---- 1%
Поздрави и успех
- emil_petrov
Още малко кондензатори
нови постъпления към 15.07.2008
К73-П3 ----- 1мкФ 160В --- 178 бр х 0.50лв
Хартия в церезин неполярни
МКВ 2мкФ 500В --- свършиха
КБГ-МН 2 мкФ 200В --- 84 х 1.50лв
Високоволтови хартиено-маслени неполярни
свършиха
свършиха
Последно промяна от emil_petrov на Чет Окт 23, 2008 11:15 pm, променено общо 7 пъти.
Skype: emil_petrov
ICQ: emil_petrov
Phone: 02/8845977
GSM: 0885590692
София
Skype: emil_petrov
ICQ: emil_petrov
Phone: 02/8845977
GSM: 0885590692
София
- emil_petrov
Skype: emil_petrov
ICQ: emil_petrov
Phone: 02/8845977
GSM: 0885590692
София
Skype: emil_petrov
ICQ: emil_petrov
Phone: 02/8845977
GSM: 0885590692
София
- emil_petrov
кондензатори втора употреба
втора употреба :
К40У9 - 1мкФ 200в - 3 х 2.00
К40У9 - 0.47мкФ 400в - 1 х 1.00
К40У9 - 0.22мкФ 400в - 1 х 1.00
К40У9 - 0.22мкФ 1000в - 2 х 1.00
К40У9 - 0.33мкФ 630в - 1 х 1.00
К40У9 - 0.047мкФ 1000в - 2 х 0.50
К40У9 - 0.022мкФ 400в - 1 х 0.50
К40У9 - 0.047мкФ 400в - 1 х 0.50
керамични цокли за печатен монтаж ( от платки )
--- 9 кр 13бр х 0.50
--- 7кр - 7бр х 0.50
МБГП-1 15мкФ 200В -2 х 2лв
МБГП 30мкФ 160В -3 х 2лв
Skype: emil_petrov
ICQ: emil_petrov
Phone: 02/8845977
GSM: 0885590692
София
Skype: emil_petrov
ICQ: emil_petrov
Phone: 02/8845977
GSM: 0885590692
София
- emil_petrov
високоволтови кондензатори
К15-5 ..... 4.7nF/ 6.3kV ...... 8бр.х 1.50 Ф30 х 5 мм керамичен
К15-5 ..... 2.2nF / 6.3kV ...... 3бр.х 1.50 Ф30 х 5 мм керамичен
К15-5 ..... 4.7nF/ 3kV ........... 6бр.х 1.00 Ф30 х 5 мм
К15-5 ..... 470pF/ 6.3kV ...... 23бр.х 0.80 Ф10 х 4 мм
К15-5 ..... 470pF/ 1.5kV ...... 9бр.х 0.30 Ф10 х 2 мм
КВИ-2 .....100pF / 10kV ........8бр.x 1.00
КВИ-2 ..... 68pF / 20kV ........ 3бр.x 1.50
КВИ-2 ..... 150pF/ 16kV ........ 1бр.x 1.50
MYFLEX 1000pF 12kV .... 1 x 6.00 ( 3 извода, залят, 110х50х27мм )
BOSCH - 5nF 2.8kV .........1 х 4.00 ( диск с отвор Ф30 х 5 )
SIEMENS - 2.2 nF / 2kV ...3 x 3.00
Skype: emil_petrov
ICQ: emil_petrov
Phone: 02/8845977
GSM: 0885590692
София
Skype: emil_petrov
ICQ: emil_petrov
Phone: 02/8845977
GSM: 0885590692
София
