Проект със драйвери Tannoy 2528 coaxial Driver 1979-1980г.
Re: Проект със драйвери Tannoy 2528 coaxial Driver 1979-1980
#91 Мнение от Nanko Rusev »
Владо, объркал си се... дунапрена/пяната е на гърба, решетките пред говорителите са като на музикантски колони.
п.п. и аз първо се обърках така .... между другото JBL са имали колона с такава визия на решетката :roll:
Wolf had seen the use of foam plastic as coverings for microphones -- either as breath filters in the studio or as wind shields in outdoor applications. He reasoned that, if the plastic was sufficiently open to sound transmission at the very low sound pressure levels encountered in microphone use, it surely would be transparent enough for a loudspeaker grille. Investigation proved this to be the case. Reticulated or open-pore foam tested out as better than most conventional grille fabrics. Wolf has stated that, while he cannot be absolutely sure of this, it appears that the L100 was the first use of shaped foam as a loudspeaker grille material.
Methods for contouring and shaping foam were fairly sophisticated, even at that time, and a striking deep waffle-like pattern was quickly devised that lent itself to the available production methods. The question of color became the next stumbling block. The integrally-colored material options were all too dull and weak to be acceptable. Dyeing did not work well. Finally, someone in JBL's Manufacturing Division (probably Tony Pacheco, Manufacturing Manager) attempted the obvious: paint it. A compatible paint formulation was found and, with the viscosity carefully controlled, the openings in the foam did not fill during the spray process. This happy result made it economically feasible to offer the L100 with three grille color options.
източник: LansingHeritage
Dgd
#92 Мнение от Dgd »
Да бе, приятели, наистина ми стана интересно и поради ниската резолюция не можах със сигурност да разбера какво гледам...
EmilRachev
#93 Мнение от EmilRachev »
Nanko Rusev написа:между другото JBL са имали колона с такава визия на решетката :roll:
По-скоро баш Таной имат подобен дизайн на гриловете, примерно модела им Ланкастър лъскавата версия виж как са отпред:
http://i.ebayimg.com/t/TANNOY-LANCASTER ... 880000500F
Предполагам Владо баш с това изпълнение се е объркал. :wink:
ТУК
kygar
#94 Мнение от kygar »
Както правилно е забелязал Нанко,на гърбът на колоната е поставен акустичен панел,патент :D на ДРГеоргиев.Има наистина освен визуален,но у положителен акустичен ефект!А отпред има обикновена предпазна решетка,която неминуемо ще влошава звукът,но щом има деца ,които пипат-няма друг начин.
EmilRachev
#95 Мнение от EmilRachev »
Този твой патент го ползвам повече от 10 години вече, но е подвижен вариант. :mrgreen:
При тонколони със заден басрефлекс баса удря в задната стена и рефлектира обратно в задния панел на колоната.
Затова срещу бас рефлектора демпвам с вата или възглавница, а на гърба на самата колона лепя с двойнозалепващо парчета дебела вата. :wink:
ТУК
#96 Мнение от DRGeorgiev »
Да, :) използвам задния панел на От като акустично пано. Не е по стандартите, но моят приятел нямаше против, на моите ОТ с 2528 нямам понеже задния ми панел е малък в.664мм. на 360мм. Идеята ми дойде от първия ми проект с 2528 :)
EmilRachev
#97 Мнение от EmilRachev »
Много по-красиво е станало, затова и те питах няма ли да ги лакираш.
Можеше да ползваш и от оцветените лакове с цел затъмняващ и леко оцветяваш ефект с червена нотка, за по-винтидж вид.
Те доколкото съм запознат моделите на Таной не са с корк отпред, само прилича визуално на твоя вариант, но на практика е едно скъпарско дърво.
Както и да е, много добре стават на външен вид, браво! :wink:
ТУК
#98 Мнение от DRGeorgiev »
Благодаря, останаха табелите TANNOY да поръчам, да сменя закрепващите винтове на драйвера и да мисля с какъв сериозен фундамент да ги повдигна, той трябва да е с височина около 400-450мм.
EmilRachev
#99 Мнение от EmilRachev »
На мнение съм, че трябва да избереш стойки, които да не убият ретро визията на колоните.
Стандартните метални стойки са неподходящ вариант в случая, по-скоро можеш да взаимстваш идея от тук:
http://www.ebay.com/itm/Vintage-70s-Woo ... 2ec0a62199
Не изглеждат толкова трудни за изпълнение, при повече старание ще можеш гарантирано да се справиш.
А във връзка с новия ти аватар гледай на каква смешна цена има обява за ГРФ Мемори:
http://www.ebay.co.uk/itm/TANNOY-GRF-ME ... 19d3e376aa
До края на търга обаче ще скочат значително, гаранция. :)
ТУК
Потребители разглеждащи този форум: 0 регистрирани и 29 госта
