Поздрави
DYE type 0-4 is cyanine or AZO which is long strategy. Long strategy means your writer need to have the laser swithched on longer to get the correct pit size. Cyanine type discs is slowly disappearing now, but they may still work better with some older writers (4X and older)
DYE type 5-9 is phthalocyanine which is short strategy. Short strategy means that the laser have to be on for a shorter time to get the correct pit size. Better lifespan, reflectivity and compatibility. Works better than cyanine at high speeds but may have problems with some old writers due to the writers not knowing the right write strategy for these new discs.
