КСО-1Б Военно изпълнение на СССР
параметри (размери) ............./бр./....................Цена:
51пф/250В (5х7.5х13.5мм).......47.................0.30лв./бр.
56пф/250В............................13..................0.30лв./бр.
62пф/250В..........................160..................0.30лв./бр.
68пф/250В............................50..................0.30лв./бр.
75пф/250В............................70..................0.30лв./бр.
82пф/250В..........................536..................0.30лв./бр.
91пф/250В............................53..................0.30лв./бр.
100пф/250В (5х7.5х13.5мм).....18..................0.30лв./бр.
100пф/500В..........................63..................0.30лв./бр.
110пф/500В..........................18..................0.30лв./бр.
120пф/250В..........................90..................0.30лв./бр.
130пф/250В..........................25..................0.30лв./бр.
160пф/250В..........................29..................0.30лв./бр.
180пф/250В..........................26..................0.30лв./бр.
200пф/250В..........................35..................0.30лв./бр.
220пф/250В..........................32..................0.30лв./бр.
240пф/250В..........................72..................0.30лв./бр.
270пф/250В........................320..................0.30лв./бр.
300пф/250В..........................60..................0.30лв./бр.
330пф/250В (5х7.5х13.5мм)......2..................0.30лв./бр.
430пф/250В (5х7.5х13.5мм)......2..................0.30лв./бр.
470пф/250В..........................50..................0.30лв./бр.
500пф/250В (REMIX)................6..................0.50лв./бр.
510пф/250В (5х7.5х13.5мм)......2..................0.30лв./бр.
560пф/250В..........................35..................0.30лв./бр.
560пф/500В..........................50..................0.40лв./бр.
680пф/250В..........................44..................0.30лв./бр.
680пф/500В..........................53..................0.40лв./бр.
750пф/250В............................9..................0.30лв./бр.
750пф/500В..........................10..................0.40лв./бр.
820пф/500В............................8..................0.40лв./бр.
КСО-2 Военно изпълнение на СССР
100пф/500В (6x11x18.5mm)........49................0.40лв./бр.
120пф/500В (6x11x18.5mm)........1..................0.40лв./бр.
130пф/500В (6x11x18.5mm)........5..................0.40лв./бр.
150пф/500В (6x11x18.5mm).......10..................0.40лв./бр.
160пф/500В (6x11x18.5mm)........4..................0.40лв./бр.
200пф/500В (6x11x18.5mm)........8..................0.40лв./бр.
220пф/500В (6x11x18.5mm).......28..................0.40лв./бр.
240пф/500В (6x11x18.5mm).......12..................0.40лв./бр.
270пф/500В (6x11x18.5mm).......16..................0.40лв./бр.
300пф/500В (6x11x18.5mm).....133..................0.40лв./бр.
330пф/500В (6x11x18.5mm).....118..................0.40лв./бр.
360пф/500В (6x11x18.5mm).....115..................0.40лв./бр.
390пф/500В (6x11x18.5mm).....132..................0.40лв./бр.
430пф/500В (6x11x18.5mm).....110..................0.40лв./бр.
470пф/500В (6x11x18.5mm).......54..................0.40лв./бр.
470пф/500В (TESLA)............ .....34..................0.40лв./бр.
510пф/500В (6x11x18.5mm)......173.................0.40лв./бр.
560пф/500В (6x11x18.5mm)......134..................0.40лв./бр.
620пф/500В (6x11x18.5mm)........11..................0.40лв./бр.
680пф/500В (6x11x18.5mm)........37..................0.40лв./бр.
750пф/500В (6x11x18.5mm)........51..................0.40лв./бр.
820пф/500В (6x11x18.5mm)........31..................0.40лв./бр.
910пф/500В (6x11x18.5mm)........32..................0.40лв./бр.
1000пф/500В ...........................394..................0.50лв./бр.
1200пф/500В ..........................119..................0.50лв./бр.
1300пф/500В ..............................6..................0.50лв./бр.
1500пф/500В..............................50.................0.50лв./бр.
1800пф/500В ...........................161.................0.50лв./бр.
2000пф/500В .............................72.................0.50лв./бр.
2400пф/500В............................415.................0.50лв./бр.
КСО-5(Б, В) Военно изпълнение на СССР
560пф/500В (7x20x20mm)..........15..................0.50лв./бр.
620пф/500В (7x20x20mm)...........5..................0.50лв./бр.
680пф/500В (7x20x20mm)...........1..................0.50лв./бр.
1000пф/500В............................43..................0.50лв./бр.
1100пф/500В (7x20x20mm)........11..................0.50лв./бр.
1300пф/500В (7x20x20mm)........11..................0.50лв./бр.
1500пф/500В (7x20x20mm)........18..................0.50лв./бр.
1800пф/500В............................15..................0.50лв./бр.
2000пф/500В (7x20x20mm)........38..................0.50лв./бр.
2200пф/500В (7x20x20mm)..........1..................0.50лв./бр.
2400пф/500В (7x20x20mm)........33..................0.50лв./бр.
2700пф/500В............................41..................0.50лв./бр.
3000пф/500В (7x20x20mm)........42..................0.50лв./бр.
3300пф/500В............................27..................0.50лв./бр.
3600пф/500В (9x20x20mm)........21..................0.50лв./бр.
3900пф/500В (9x20x20mm)........31..................0.50лв./бр.
4300пф/500В (9x20x20mm)........41..................0.50лв./бр.
4700пф/500В (9x20x20mm)........19..................0.50лв./бр.
5100пф/500В............................79..................0.50лв./бр.
5600пф/500В (9x20x20mm)........17..................0.50лв./бр.
6200пф/500В (9x20x20mm)........27..................0.50лв./бр.
6800пф/500В............................46..................0.50лв./бр.
7500пф/250В............................10..................0.40лв./бр.
8200пф/250В............................23..................0.50лв./бр.
10000пф/250В..........................12..................0.70лв./бр.
0.01мкф/250В (9x20x20mm)........2..................0.70лв./бр.
КСОT-5-Г Военно изпълнение на СССР
6800пф/500В..........................200..................0.50лв./бр.
КСО-6 Военно изпълнение на СССР
560пф/1000В...........................1..................1.00лв./бр.
1000пф/1000В (9x17x27mm)......5..................1.00лв./бр.
2000пф/1000В..........................1..................1.00лв./бр.
2700пф/1000В..........................1..................1.00лв./бр.
КСО-7 Военно изпълнение на СССР
100пф/2500В.............................1..................1.00лв./бр.
360пф/2500В.............................1..................1.50лв./бр.
1000пф/2500В..........................16..................2.00лв./бр.
КСО-8 Военно изпълнение на СССР
1000пф/2500В..........................8..................2.00лв./бр. продадени
1800пф/2500В.........................20..................2.00лв./бр.
3000мкф/2500В........................2..................2.00лв./бр.
5100мкф/1500В........................5..................2.50лв./бр.
6800мкф/1500В........................3..................2.50лв./бр.
6800мкф/1600В......................10..................2.50лв./бр.
10000мкф/1000В........................4..................2.50лв./бр.
18000мкф/500В........................14..................2.00лв./бр.
0.01мкф/250В........................130..................3.00лв./бр.
0.01мкф/1000В..........................8..................3.00лв./бр.
0.015мкф/250В..........................8..................3.00лв./бр.
0.018мкф/250В........................31..................3.00лв./бр.
0.018мкф/500В..........................9..................3.00лв./бр.
0.02мкф/500В..........................50...................3.00лв./бр.
0.022мкф/500В........................12..................3.00лв./бр.
0.024мкф/500В..........................1..................3.00лв./бр.
0.027мкф/500В.........................10..................3.00лв./бр.
КСО-10В Военно изпълнение на СССР
1000mmF+-5%, 3000V................1..................3.00лв./бр.
КСО-12 Военно изпълнение на СССР
1000пф/3000В..........................2..................3.50лв./бр.
15мкф/5000В...........................2..................3.50лв./бр. продадени
39мкф/5000В...........................3..................3.50лв./бр.
КСО-13 Военно изпълнение на СССР
1000пф/5000В..........................8..................4.50лв./бр.
1800пф/5000В............................1..................4.50лв./бр. продаден
СПИСЪКА ЩЕ БЪДЕ ДОПЪЛВАН!!!
За връзка:
vtraikov@gmail.com
Продавам Слюдени аудио конденз. тип КСО-1Б, 2, 5, 6, 7, 8, .
Temenuzhka_Venko56
- Местоположение: Благоевград
Последно издигане Temenuzhka_Venko56 от Чет Сеп 08, 2016 5:58 pm
+359885553535
