Дискови кондензатори
100pF, 22kV (ф17х5мм)..................59бр..................0.30лв./бр.
100pF, 25kV (ф19х5мм)................326бр..................0.30лв./бр.
330pF, 22kV (ф22х3мм)................235бр..................0.30лв./бр.
КТ-1 и КТ-2 - тръбни руски конд.
тип КТ-1 (ф2.5х11мм) (сн. КТ1$KT2 по-горе)
1.5pF+–0.4pF, М47...............1700бр..................0.10лв./бр.
6.2pF+–0.4pF, М47.................200бр..................0.10лв./бр.
12pF+–5%, М750.....................90бр..................0.10лв./бр.
12pF+–10%, М750................5680бр..................0.10лв./бр.
15pF+–5%, М750..................2000бр..................0.10лв./бр.
24pF+–5%, М750..................1000бр..................0.10лв./бр.
33pF+–5%, М750....................500бр..................0.10лв./бр.
39pF+–5%, М750..................2000бр..................0.10лв./бр.
47pF+–10%, М750..................185бр..................0.10лв./бр.
51pF+–5%, М47.......................49бр..................0.10лв./бр.
62pF+–10%, М750.................1000бр..................0.10лв./бр.
75pF+–5%, М47........................50бр..................0.10лв./бр.
120pF+–5%, М1500.................690бр..................0.10лв./бр.
тип КТ-2 (ф4х12.5мм) (сн. КТ1$KT2 по-горе)
3.3pF+–0.4pF, М750................195бр..................0.14лв./бр.
3.9pF+–0.4pF, М750................500бр..................0.14лв./бр.
4.7pF+–0.4pF, М750...............1000бр..................0.14лв./бр.
5.1pF+–0.4pF, М47................1000бр..................0.14лв./бр.
5.6pF+–0.4pF, М750..............1000бр..................0.14лв./бр.
7.5pF+–0.4pF, М47..................500бр..................0.14лв./бр.
12pF+–5%, М47....................1000бр..................0.14лв./бр.
20pF+–5%, М750..................1000бр..................0.14лв./бр.
39pF+–10%, М750..................383бр..................0.14лв./бр.
47pF+–10%, М750..................500бр..................0.14лв./бр.
68pF+–5%, М750....................250бр..................0.14лв./бр.
100pF+–10%, М750.................1000бр................0.14лв./бр.
150pF+–10%, М1500...............1000бр..................0.14лв./бр.
330pF+–10%, М1500...............1000бр..................0.14лв./бр. (ф4х17мм)
тип КТ-3 (сн. КТ-3 по-горе)
9.1pF+–5%, М47 (ф6х13мм)....30бр..................0.40лв./бр.
56pF+–5%, М47 (ф6х21мм).....29бр..................0.40лв./бр.
100pF+–10%, М47 (ф6х31мм)..48бр..................0.50лв./бр.
vtraikov@gmail.com
Тръбни керамични конд. КТ-1, КТ-2, КТ-3 и дискови
Temenuzhka_Venko56
- Местоположение: Благоевград
Последно издигане Temenuzhka_Venko56 от Пет Ное 04, 2016 6:46 pm
+359885553535
