Продавам ролков AKAI GX-4000D
Roojo
Регистриран на: Сря Дек 27, 2006 1:00 am
#1 Мнение от Roojo »
Здравейте.
Продавам триглав ролков дек AKAI GX-4000D.
Състояние - оригинален вид, абсолютно запазен,отличен звук.
Цена - 260 лв.
Снимки:
Технически данни:
Track system: 4 track, 2 channel stereo/mono
Wow and Flutter: Less than 0,08% WRMS.
Frequency Response: 30Hz to 24,000 Hz (+-3dB at 7-1/2.
30Hz to 16,000Hz(+-3dB at 3-3/4.
Distortion: Less than 1% (1,000 Hz "0" VU.
Signal-to-Noise-Ratio: Better than 60 dB.
Erase Ratio: Better than 70 dB.
Bias frequency: 100 kHz.
Motor: (1) 4-pole induction motor.
Fast forward and Rewind time: 200 seconds using 1200 feet tape.
Input jacks: (2) Microphone: 0,25 mV. (Microphone impedance: 600 ohms).
Headphone jack.
RCA jacks for Output and Input.
DIN connection.
Low Noise / Extended Range Switching
Features Sound On Sound Capability for Multitracking.
Speed Sleeve for 7.5 IPS (19cm/s) Recording/Playback.
2 speeds: 3-3/4 & 7-1/2
220/240V - 50 Hz
Dimensions: 17,3 (440mm) Wide, 12,4(315mm) Tall, 9,1(230mm) Deep.
Weight: 29,1 lbs. (13,2 kg)
http://cgi.ebay.com/AKAI-GX-4000D-Reel- ... dZViewItem
Поздрави.
Росен.
тел.0887255757
balkan_gb@abv.bg
ICQ: 114287528
Skype: roojo6615
