Hi-End interconnects XLO Electric - ПРОДАДЕН!
YELLO
Регистриран на: Съб Окт 07, 2006 12:00 am
#1 Мнение от YELLO »
XLO Electric - Signature 3.
RCA, 2 x 1 метър.
Нови, в перфектно състояние.
Произведени в САЩ.
Продаден.
"Signature-3 interconnect and speaker cables are custom-drawn 99.99998% ("Six Nines") pure Laboratory Grade copper. Signature-3's higher specification calls for UPOCC 6N copper (Ultra Pure Ohno Continuous Casting process). Proprietary Field-Balanced™ winding -- how each signal-bearing conductor is arrayed relative to the others -- is optimized for the interactive relationship between current-controlled electromagnetic fields formed around a cable's conductors, and the electrostatic fields formed around its insulation when an audio or digital/video signal passes."
"Signature-3 are designed with to minimize capacitive discharge effects. As current passes through insulated conductors capacitance effects store signal energy in the surrounding dielectric material that's either turned into heat or quickly released out of phase back into the signal path as soon as the polarity changes leading to signal cancellations, reduced low-level detail, smearing, and out-of-phase artifacts causing spurious sound or picture distortions!"
"XLO reduces stored energy with low-mass dielectrics and the best materials with the minimum dielectric constant and the fastest "dump rate" -- the faster the energy returns or dumps from the dielectric, the less distortion you hear."
http://news.ecoustics.com/bbs/messages/ ... 27048.html
http://www.dagogo.com/View-Article.asp?hArticle=582
http://bgaudio.org/forums/viewtopic.php?f=13&t=19394
0887839788
nikikoz
Re: Hi-End interconnects XLO Electric - ПРОДАДЕН!
#2 Мнение от nikikoz »
не знам кой е взел този прекрасен кабел но задължително му кажи да си смени накрайниците за да разбере какво реално си е купил :D
