Продавам усилвател DENON AVR3801
Описание: Dolby Digital & DTS ES Discrete 6.1 A/V Receiver • DTS Extended Surround Discrete 6.1 decoding • DTS Extended Surround Matrix 6.1 decoding • DTS Neo:6 Cinema & Music Surround decoding • Dolby Digital decoding, including Matrix 6.1 decoding • DDSC-Digital featuring Analog Devices SHARC 32 bit floating point DSP processor • 7 Channels equal power amplifier section • 105 watts per channel (8 ohms, 20 Hz-20 kHz, <.05%THD) • 140 watts per channel (6 ohms, 1 kHz, <.7%THD) • Analog Devices 24 bit, 96 kHz high resolution DACs on all eight channels • Real 24 bit, 96 kHz Digital Interface Receiver • 2 sets component video inputs, compatible with wideband (480p, 720p, 1080i) response for progressive DVD, DTV • 5 sets composite and "S" video inputs • 7.1 external wide bandwidth (100 kHz) input for future multi-channel formats (such as DVD-Audio) • 5 & 7 Channel Stereo • Personal Memory Plus • 4 assignable digital inputs • Optical digital output • 9 analog inputs including built-in AM/FM tuner • Multi-Zone 1 stereo pre-amp level audio outputs, fixed or variable level • Power Amplifier Assign function, lets you assign 2 of the 7 amp channels to drive second zone speakers directly • LCD dot-matrix programmable/learning remote features TV, VCR, DVD codes from other manufacturers; backlighting main function keys (less)
Ако някой има интерес към усилвателя да ми изпрати лично съобщение.Цена 650лв.
