Продавам усилвател Biema W110II на около 9 - 10 месеца. Не е прегрявал работи перфектно. Цена по договаряне.
* Features: Rugged heavy duty construction
* 19" rack mount
* Stylish cosmetics
* Soft start limiter
* Earth lift switch
* Limiter on/off switch
* RCA & 6.35mm jack inputs
* Binding post & industry standard heavy duty output speaker connectors
* Clipping & overload/overdrive protect indicators
* Recessed detent volume controls for each channel
* Fan forced cooling
* Specifications: Output Power 8 Ohms: 2x100W RMS
* Output Power 4 Ohms: 2x170W RMS
* Frequency Response: 10Hz - 50KHz -1.5db
* Input Sensitivity: 1.4V
* Signal to Noise Ratio: >90dB
* Dimensions(WxDxH): 482x314x88
* Weight: 9.5kg
http://www.biema.com/html/product/amplifiers/w.htm" onclick="window.open(this.href);return false;
Намира се в гр. София. За връзка 0883373072 - Светльо.
- SevenHertz
- Регистриран на: Пон Юни 26, 2006 12:00 am
