Благородно завиждам на този дето ще грабне Ямахата.
Намерих малко нейни спецификации и се шашнах.
M-2
8Ohm power:2x 200W (20Hz...30kHz, 0,005% THD)
4Ohm power:
IMD:less than 0,002% (half rated power)
Frequency response:10...100kHz (8Ohm, 100W, 0,01% THD)
Bandwidth:DC...100kHz (-0,7 / +0,5dB)
Damping factor:200 (8Ohm, 1kHz)
S/N ratio:127dB (IHF-A)
Stereo separation:100dB (1kHz)
80dB (20kHz)
Inputs:1V / 25kOhm
(for 100W/8Ohm output, 470pF)
PC:1500W (max.)
Dimensions:43,5 x 18,3 x 36,2cm
Weight:23kg.
Features:gold-plated RCA inputs
gold-plated speaker outputs
2,5mm pure copper bussing
phase-corrected polystyrene caps
Linear Transfer bias switching
ground termination
AC+DC inputs
