TANNOY i12-200/400W-97db.
Публикувано на: Пет Мар 28, 2008 9:22 pm
от Anonymous
TANNOY i12-200/400W-12"-97db- коаксиален драйвър-900лв за чифт.
Публикувано на: Сря Апр 23, 2008 7:02 pm
от Anonymous
Ето и инфо!
TECHNICAL SPECIFICATIONS
Frequency Response 70Hz–25kHz
(1) ± 3dB 45Hz–25kHz (with TX2 controller)
Recommended Amplifier Power 200–400 watt / 8 ½
Power Handling (2) Average: 200 watt
Programme: 400 watt
Peak (10ms): 800 watt
Sensitivity (1) 2.83v @ 1m 97dB (Anechoic)
100 dB (Half-Space)
Maximum SPL (3) @ 1m Average: 120dB
Peak: 126dB
Impedance Nominal: 8 ½
Minimum 6.1 ½
Dispersion (-6dB) 60 degrees conical
Driver Complement 1 x 12" (300mm) Constant
Directivity Dual Concentric™ Type number 3412
Crossover Passive 1.5kHz
2nd order high pass, 2nd order low pass
Halogen & Auto-Reset HF protection
Enclosure T12 - 38.7 litre vented, 15mm birch plywood
i12 - 38.7 litre vented, 15mm MDF
Finish Textured black/grey paint
Protective Grille Perforated steel, black with 58% free airflow
Connectors 2 x Speakon NL4MP, in/out
Rigging/Fittings T12: 1 x recessed carrying handle
T12: 1 x 35mm pole mounting socket
T12/i12: 8 x M8 flying inserts & 1 x M8
pullback point
Dimensions (HxWxD) 486mm x 370mm x 385mm
(19.3” x 14.57” x 15.15”)
Weight 20kg (44lbs)
