W200S или W200SC ?
Публикувано на: Нед Фев 08, 2009 2:17 am
Здравейте. Искам да направя активен субуфер, но се затруднявам в избора между W200S и W200SC. Моля помагайте.
W200SC 4 Ohm.
technical data:
rated power 75 watt
maximum power 115 watt
nominal impedance 4 ohm
frequency response (-10 db) fu - 6000 hz
(fu: lower cut-off frequency depending on cabinet) .
mean sound pressure level 88 db (1w/1m)
maximum cone displacement 20 mm
resonance frequency fs 27 hz
magnetic induction 1,1 tesla
magnetic flux 600 µ weber
height of front pole-plate 5 mm
voice coil diameter 3,5 cm
height of winding 1,2 cm
cutout diameter 18,4 cm
net weight 2,5 kg
d.c. resistance rdc 3,3 ohm
mechanical q factor qms 3,41
electrical q factor qes 0,31
total q factor qts 0,28
equivalent volume vas 71 l
effective piston area sd 214 cm2
dynamically moved mass mms 27 g
force factor bxl 7,61 t · m
inductance of the voice coil l 1,5 mh
W200S 4 Ohm.
Rated power 75 W
Maximum power 115 W
Nominal impedance Z 4 Ohm
Frequency response fu–6000 Hz
(fu: Lower cut-off frequency depending on cabinet) .
Mean sound pressure level 88 dB (1 W/1 m)
Maximum cone displacement 20 mm
Resonance frequency fs 29 Hz
Magnetic induction 1,1 T
Magnetic flux 600 µWb
Height of front pole-plate 5 mm
Voice coil diameter 35 mm
Height of winding 12 mm
Cutout diameter 184 mm
Net weight 1,5 kg
D.C. resistance Rdc 3,4 Ohm
Mechanical Q factor Qms 3,99
Electrical Q factor Qes 0,38
Total Q factor Qts 0,35
Equivalent volume Vas 65 l
Effective piston area Sd 214 cm²
Dynamically moved mass Mms 28 g
Force factor Bxl 7,7 T m
Inductance of the voice coil L 1,5 mH
W200SC 4 Ohm.
technical data:
rated power 75 watt
net weight 2,5 kg
W200S 4 Ohm.
Rated power 75 W
Maximum power 115 W
Net weight 1,5 kg
