важен ли е разклонителя - мои лични наблюдения
Публикувано на: Чет Юли 08, 2010 7:49 am
Още в началото искам да кажа, че осъзнавам ясно че основната част от хората който ще прочетат моето мнение ще си помисля, че съм луд но понеже отдавна съм спрял да си мисля какво казват другите реших да споделя моето преживяване.
Ето малко данни за „изделието” което ме впечатли:
Furutech’s Award-Winning Pure Transmission Build Quality
Many A/V enthusiasts go to great lengths to carefully set up major system components, but pay little attention to the source, the AC power. Meticulous build quality is a large part of the engineering equation. Furutech Pure Transmission technology turns a macro lens on every element of power and signal transfer applying optimized engineering solutions to well-known problems such as contact resistance, EMI and RFI rejection, grounding, and using the best materials and processes available.
Техническо описание:
- All conductors treated with Furutech’s α (Alpha) Cryogenic and Demagnetizing Process
- FT-SDS(R) X4 nonmagnetic rhodium-plated α (Alpha) pure copper Pure Transmission schuko outlets feature nylon/fiberglass bodies incorporating carbon particles forming an extremely effective nonresonant connector body
- FI-09(R) Rhodium-plated α (Alpha) pure copper IEC Inlet to ensure Pure Transmission
- Furutech’s Axial Locking System lowers receptacle resonance by a factor of 10
- Beautifully-crafted highest grade aluminum Carbon fiber finished plate.
- Highest-grade aluminum chassis effectively shields against RFI (Radio Frequency Interference)
- A layer of Formula GC-303 bonded to the bottom plate effectively shields against EMI (Electro Magnetic Interference)
- Star-wired conductors using Furutech α (Alpha)-10, 5.5 sq. mm (10 AWG) for low electrical resistance, conductors insulated within resonance-absorbing tubing
- Dimension: 298(L) X141(W) X80(H) mm ± 1mm (Including feet)
- Net Weigh: 3.5kgs Approx.
И сега моята история. Когато взех решението да „инвестирам” пари в разклонител изобщо не си давах сметка какво реално правя. Донесоха ми два варианта на родиеви разклонители (TP309E & TP609E) от който трябваше да реша кой да взема. След няколко секунди осъзнах, че избора ще е много лесен. Разликата в звученето между двата разклонителя (знам че вероятно звучи абсурдно) е огромна и не може да се говори за „пласибо” а за ясни, чуваеми и категорични разлики. Толкова големи, че в един определен момент си задаваш въпроса ”аз какво сменям всъщност”. Няма да говоря за баси, високи или среди...разликата е в цялостното звучене на системата, просто коренна промяна дори на цялостния тембър на звучене на системата. Няма да продължавам да възвалявам разклонителя защото никой няма да ми даде пари за това но искам да споделя един лично мой извод. ТОКА Е ВАЖЕН ПОНЕ КОЛКОТО ВСИЧКО ОСТАНАЛО В СИСТЕМАТА. Оставям всеки сам да тълкува думите ми но знам, че никой не е в състояние да ме разбере до като не чуе сам за какво говоря. Поне при мен беше така, ако до вчера някой ми беше казал, че има смисъл да харчиш пари за хай енд раклонители щях да съм убеден че е така но нямаше да си давам сметка за какво изобщо ми говорят.
Пожелавам музикална нирвана на всички.
